Different max strobe speed in freestyler and 192-channel remote control
Gorat
Just started using FS
FreeStyler Version: 3.6.51
Post by Gorat »
There is a strobe.
When connected to a remote control (a normal 192-channel remote control), the maximum flashing speed is faster than if the speed fader is turned off to 255 in the Freestyler.
The speed channel settings are specified min = 0, max 255.
What can this be related to?
FreeStyler Version: 4.01
Re: Different max strobe speed in freestyler and 192-channel remote control
Post by Partyman »
most likely one is using dmx control and the other is accessing built in macros
Gorat
Post by Gorat »
Partyman wrote: 10 Aug 2020, 07:58 most likely one is using dmx control and the other is accessing built in macros
Hmmm, in both cases, I use a dmx connection. And I control the speed through the fader(both on the remote control and in the Freestyler2)
Post by Partyman »
If you have a really cheap USB to DMX the refresh rate can be slower and cannot be adjusted. I use the Enttec Pro micro and in the Freestyler setup you can adjust the refresh rate (I use the lowest setting it will allow).
Maybe that is reason?
SiGNe
FreeStyler Version: 4.14
Post by SiGNe »
Or you have "Link sliders with channel functions" on (under the setup tab)
Ik i have that on the strobe settings on my Mega hex Pars doesn't work corectly either.
The random strobe on the pars go to 223, anything above that turns the strobe off and the lights on, 0 is strobe off + lights off
With Link Sliders on those settings go up to 255 and 255 is random strobe while 0 is the normal fast strobe.
