3 New Stage Right Fixtures from Monoprice
christofori
FreeStyler Version: 3.6.51
Post by christofori »
Hey all,
First post here -- but I've been using FreeStyler for a while.. So, I recently replaced the main lights in my rig (I'd had some old American DJ P36LEDs and a P64LED -- which each had some ... issues... due to age!) with newer/better ones which I found online from monoprice.com. As near as I can tell, they are indeed the manufacturer. They sell/provide a line/brand called "Stage Right" and have a pretty wide variety at reasonable prices.
Anyway, I chose to replace the P36's with something fun -- the Monoprice Stage Right Party Wash FX[/url]. The face is divided up into 6 "slices" or segments, each RGB -- gives you a pretty neat flickering shadow effect.
I replaced my P64LED with the Monoprice Stage Right PAR-575
And for fun, I decided to also try a new fixture...: Monoprice Stage Right Party Mini Beam. It's a movable head fixture with a single 1W RGBW LED in it, so it makes 4 individual beams (one for each color) which can fade or strobe. For the price, it's actually pretty impressive.
So -- attached, there should be three .pff files -- one for each type of fixture described herein. :D I got creative with the macro images on the Party Wash FX.
Hope these might come in handy for someone else out there, some day...! :)
All three of these are the initial release versions (v1.0) and have been thoroughly tested with the actual fixtures. On the Par575 there can be either 3, 4, 5, 8, or 9 channel DMX control modes; but I went with 8; the other fixtures specify the channel mode in the filename.
Image of the Party Wash FX
Image of the Party Mini Beam
Monoprice_StageRight-PartyWashFX-x54LED(23ch Mode).pff
23ch DMX Mode, v1.0
(74.77 KiB) Downloaded 112 times
Monoprice_StageRight-PartyMiniBeam(13ch Mode).pff
13ch DMX Mode, v1.0
(14.31 KiB) Downloaded 121 times
Monoprice_StageRight-PAR-575.pff
8ch DMX Mode, v1.0
(28.86 KiB) Downloaded 116 times
