I have used it, set up a stage seen my lights in action, at first it booted up once in a while and I would just restart Freestyler several times and once in a while it would start from the 3D icon, Now I can not get it to. I have read all the post and done all the suggestions, several re installs of Freestler and Magic 3D and still nothing. Any suggestions. And this is on 2 different PC's. I really have tried everything. Sometimes it opens from the window drop down, but not now, sometimes it opens if I switch back and forth between interfaces, but now it will not open at all, the circle starts spinning and just fades away.
Thanks so much for any insight.
Magic 3D will not boot from Freetsyler all the time
perrip
- Commited FS Forum helper
- FreeStyler Version: 4.1.7
- djSupport
Re: Magic 3D will not boot from Freetsyler all the time
The problem with Easyview 3d is that it is a from a different company and as such it could be an issue with their software, perhaps try contacting them https://www.sunlitepro.com/en/home.htm
Or if you think it's an FS Bug then report it here: https://www.freestylersupport.com/bugs
perrip
Hey Thanks, I can get it to work once in a while, I just have to reboot freestyler a few times and eventually it will fire up. Thanks so much for getting back to me
- djSupport
No problem
