Hi everyone. I come across a problem that I can't solve. Maybe someone knows something ! Supposing you have some cue active from submasters and you want to modify some parameters and then save it into a sequence. how i can do it? Because when i modify the parameters and open the sequence editor (that is in offline mode) i can't save that changes! And also if someone can explain the offline mode again because i can't understand well how it works !
Thank you !
Problems with sequence editor and offline mode
- FreeStyler Version: 3.6.51
- FreeStyler Version: 4.01
Re: Problems with sequence editor and offline mode
You have to either not have the cue or S2L windows open or running or learn to program in offline mode. Any changes you make and save in offline mode will show when the sequence is relaunched. Offline mode means that you cannot see the changes you are making until you: change values, save sequence and relaunch the sequence.
The easiest way to program fixtures in offline mode is before you ever open the sequence editor you need to make the changes that you want to make (at this point you are not in the editor and changes will be visible). When you have what you like, write down the channel values for any channels you change and then open the editor(which will be in offline mode) and change the values to what you wrote down, save sequence, relaunch sequence and all should work correctly.
