Scratching my head here. All of a sudden, Freestyler no longer detects the NanoPad2 under External Control > MIDI Devices. No longer in the drop down. I didn't change anything in settings, but I did try a different USB cable, different USB port, and even another NanoPad2. Win10 sees it in the device manager, and the white LED lights up in the upper left corner of the unit. I'm running v3.6.49, which may not be the latest version, but nothing (else) changed that would suggest updating being the solution.
Any ideas or suggestions?
Korg Nanopad2 no longer detected in Freestyler x2
- FreeStyler Version: 359
Re: Korg Nanopad2 no longer detected in Freestyler x2
OK...figured it out. Driver for the NanoPad2 was out of date. Apparently one of Win10's mandatory updates rendered it useless. Had to uninstall completely then reinstall new driver then it saw it again.
