Support for RGBAWUV lights Topic is solved
SiGNe
FreeStyler Version: 4.14
Post by SiGNe »
These days you see more and more suppore for fixtures with RGBUV and RGBAWUV but Freestyler doesn't officially support UV lights.
You can use Warm White or Cold White since one of the two isn't used in fixtures with UV ofcourse so you can make it work easily but esthetically it would be nice to have a seperate channel for UV.
And maybe there will be "septa" LEDs in the future too? RGBAWWCWUV maybe?? ;)
mleferink
Re: Support for RGBAWUV lights
Post by mleferink »
Good idea!
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Not sure what happened to the link but I suggest you post this request here:
https://www.freestylersupport.com/bugs/login_page.php
This is (or was) where bugs are reported AND new features are requested.
Post by Jan_K »
@Rod_Horning, I think Adam is working on the link issue.
Yes apologies I got way laid, the links were removed by a forum upgrade, it wasn't a simple fix and then I forgot to go back to it! The link is still on the https://www.freestylersupport.com page. I'll aim to fix it tonight UK time my apologies!
Thanks for the info guys.
Fixed :) any other things just let me know!!
petergesell
FreeStyler Version: 3.6.3
Post by petergesell »
Hi
I don´t know elsewhere to write, so i put it here, English is not my language, so sorry for bad writing.
At these times, more and more fixtures come with way more colors and even motors , than they used to have.
So, my question, my wish, should i say, is that fixtures can be better declared in order to achieve audioritmic capabilities. It would be very nice to allow specific channels by users choice to get random values , also between desired ranges, in audiorritmic mode. This, instead the standart way to declare 2 motors for pan and tilt, and rgb for colors
Specifically, could mention a fixture type spider, with 3 motors and 5 colors per lamp, with 8 independent from those. It would be very nice to be able to allow independly random values, inbetween a range, if possible, for any of the 43 channels mentioned, that reacts randomly by beat detector.
Very much thanks
You can use custom sliders to add functions that don't have a place for them. I.e. 2 pan channels. You should request any features by using the bug tracker in the 'quick links' menu
Return to “Ideas and Remarks”
