Laserworld ES-400RGB QS
Raider555
Just started using FS
FreeStyler Version: 3.6
Post by Raider555 »
Hello Gentlemens,
I have 2x lasers ES-400RGB QS. I want to add these to Freestyler but I can't find working fixture.
I found fixture in other topic : viewtopic.php?f=8&t=6671&p=27234&hilit= ... 400#p27234
but channels in this fixture are mixed and not working good.I mean channel for rotation or colors are not correctly set(this is example).
goobos and total channels(in my laser is 12) are not choosed correctly too.
Could someone please help me how to correctly set it ?
Below is a instruction for this laser:
https://www.laserworld.com/en/support/d ... 16-09.html
One more question:
What that means for example n0 colors in fixture creator?
Thank you for your help! ;)
FreeStyler Version: 4.1.7
Re: Laserworld ES-400RGB QS
Post by Rod_Horning »
The n0 colors in Fixture Creator is used to create a color wheel. In the color wheel you define the DMX value and place a picture of the color. During programming you can open a color window after you select the instrument. Clicking on the color you desire will set the channel to the appropriate DMX value.
If you have downloaded the user manual please attach it to a post in this thread along with your exported fixture file. We can examine your fixture file to see if any changes need to be made.
