Can't get Freestyler and 3d Magic Viewer To Communicate
skelly69
FreeStyler Version: 3.6.6
I Use FreeStyler for: Band
Post by skelly69 »
Hey y'all, so, here's my problem:
I have gotten 3D Magic Viewer to say it's being controlled by Freestyler, and the green light says DMX is on, but when I turn my lights on in FS nothing happens in 3D????????? I've searched thru the forums, but have found nothing relating to my OS (Win 10). If anyone has had the same issues and figured it out would love to hear the solution!!!
Thanks all!!!!
Erik
Nathanrs93
FreeStyler Version: None
Re: Can't get Freestyler and 3d Magic Viewer To Communicate
Post by Nathanrs93 »
Hey
Try this topic. It might help you
viewtopic.php?f=56&t=5579
