Assign problems
Rubenfilipe
Assign problems
Post by Rubenfilipe »
Hello from Portugal :)
I started today using freestyler and I'm loving it!
I have a question
I create a scene and then in definitions I assigned number 1 on computer to start and stop and assigned the + to increase the speed of scene and saved
Everything works fine but if I close the program and open it again I need to assign again
I'm doing something wrong or it's a bug from the freestyler last version?
Re: Assign problems
You can set freestyler to remember that last used values so if you close down it will reopen the same if not it will always reopen sending out the dmx values '0'
Rubenfilipe
Re: Assign problems
I have done that but when I open the freestyler, the only thing that remains saved it's the favourite scene
