REQUEST: Chauvet Intimidator Spot 110
petemcknz
FreeStyler Version: 3.6.4
I Use FreeStyler for: Band
Post by petemcknz »
Please see attached file with the DMX values. Requesting a fixture file for 12 Channel please. Thanks!
Intimidator_Spot_110_QRG_Rev1_ML6.pdf
(1.16 MiB) Downloaded 37 times
FreeStyler Version: 4.1.7
Re: REQUEST: Chauvet Intimidator Spot 110
Post by Rod_Horning »
Attached is my attempt at a fixture definition. Please test and provide feedback.
Download, Import and add the fixture to Freestyler
Click on the Fixture
Click on Window -> All
This will open, in addition to the standard Freestyler sliders, the following helpful programming windows:
Colors
Gobos
Lamp
Pan/Tilt
Custom Sliders.
Gobo 2 and Gobo 3 are NOT gobos but control the blackout and movement macro features (Channel 10 and 11)
The custom sliders provide easier control of the various strobe functions.
I could not tell from the manual but it seems that the user might be able to place gel in the various positions of the color wheel. If this is true I could change The Colors window to display the color you insert.
Chauvet_Intimidator_Spot_110_12ch.pff
(110.04 KiB) Downloaded 53 times
