Fanning Help
ned911
Fanning Help
Post by ned911 »
Trying to get my MinSpots (2) to fan. I've got both fixtures selected, they are set to different DMX channels, but when I click Set Fan nothing happens. Expectation was that each fixture would position at 45 degrees opposite of each other. Is there something not set right in my fixture file? Or did I do something else wrong.
daantas
Re: Fanning Help
Post by daantas »
Use the search function of this forum, this topic has already been mentioned very much
ned911
Re: Fanning Help
Post by ned911 »
I know what fanning is (cause you wrote a great article on it), what I'd like to know is why nothing happens when I click the Set Fan button.
bojan.cadjenovic
Re: Fanning Help
Post by bojan.cadjenovic »
I have same problem with 6 futurelight mh660.but when i click on SET FAN only works pan option
Bubbl
Re: Fanning Help
Post by Bubbl »
Same problem!
I tried it with 5 MHs
Re: Fanning Help
have you bug reported this?
Bubbl
Re: Fanning Help
Post by Bubbl »
ehm... no!
Does it run in the older freestyler version? or is it only a problem in my software/pc?
