Hi all,
I was wondering Raphael if it is possible to implement something so i can select which channels of a fixture will be used by react to sound (random values). Now only RGB and pan/tilt/gobo are used, but i would like WW and strobe also to be used sometimes.
Thanks at least for diving into it.
Andre
Checkboxes to select channels in react to sound
DreNL
- FreeStyler Version: 4.1.7
- Laudrin
- FreeStyler Version: 3.6.49
Re: Checkboxes to select channels in react to sound
That would be a nice feature. Until then you can maybe use the flash button option in Sound2Light, triggering specific override buttons.
I don't know if it's the same in the stable version because I installed the beta of S2L, but you should be able to find it under "Config", "Beat flash" and then choose the number of that override button you would like to flash per beat.
