HI all, this is our first topic in this forum.
We are experincing an issue with FS ver. 3.6.45.
We are using more than one Cue List, when we try to switch from one cue list to another they will freeze, all the channel remai at the last leve, and we cannot shut off. To fix we have to restart FS.
We are use the software with Win 10 and DMX-USB Pro MK2 USB/DMX - Interface...
Somebody can help us?
FS freeze on Cue List Change Topic is solved
- Laudrin
- FreeStyler Version: 3.6.49
Re: FS freeze on Cue List Change
Are you sure this is a freeze which did not occur in previous versions of FreeStyler?
It may be just a configuration issue:
Try the "restore value" option (the 5th symbol in each cue window row, the curved blue arrow) or the "cue multiselect always enabled" (left option cog wheel or in FreeStyler Setup).
Please give a short feedback if that helped.
