Colorspot 250at 3d Model is missing
Krauthaus
FreeStyler Version: 3
I Use FreeStyler for: None of your damn business!
Post by Krauthaus »
Hi there!
The Colorspot 250at from Robe is in the fixture library, but If I try to insert it to a stage this message appears:
"Cannot add fixture, an error occured while building the fixture (3D Object is maybe missing)"
Then a new window appears, "Easy View Library - Missing Files".
In there a table with only one Entry tells me that the file "EasyViewLibrary\Fixtures\L051.x1" is missing.
Is there any workaround for this? Is this fixture maybe just not present in the free version`?
I really would apprechiate some help:D
Best regards
krauthaus
Krauthaus
Re: Colorspot 250at 3d Model is missing
Post by Krauthaus »
Ok, If somebody stumble upon the same problem: You can use the fixture editor to assign a other model to your moving head.
