Messages from Freestyler to plugin ?
kabak_85
FreeStyler Version: 3.646
Post by kabak_85 »
Hello,
I have read the documentation "external control for FreeStyler" in order to understand how plugins communicate to freestyler.
The document describe how the plugin have to send message in order to change outputs value, load and run sequences or send simple command (same as midi).
But is there "event" message from Freestyler to the plugins like "this override button as changed", "this trigger midi is activated", "the sequence 1 go to the step 2" ?
I had see some TCP/IP command in order to get status from buttons and cue but it seems there nothing similar in the windows message.
This document had 5 years so it can be incomplete.
Best regards.
Speak English / Parle Français.
Laudrin
FreeStyler Version: 3.6.49
Re: Messages from Freestyler to plugin ?
Post by Laudrin »
Is there any solution / clarification yet?
