MantisBT is mailing me all the bug reports instead of only the S2L ones.
FreeStyler Version: N/A
Post by remco_k »
To be clear: its not a new problem. Its been doing that since the beginning, and I had created a filter in my e-mail to just dump them in a dark hole where the sun doesn't shine.
Yet, I'm thinking there must be a way that I can configure -somewhere- in MantisBT to only send me e-mail if someone submits something for S2L.
I looked around, didn't find it.
Any suggestion where I can change that e-mail behaviour?
Re: MantisBT is mailing me all the bug reports instead of only the S2L ones.
In your settings it will have email options by default it is set to remind you of 'any' of a multitude of things you need to change that to 'me' our something similar
Post by remco_k »
That lets me only choose the severity, like Bug, crash, tweak, any,...
It does not let me choose to receive only for Sound 2 Light.
Is that even possible?
sorry for the delay those damn email notifications! Set the default project and make your changes!
Return to “Ideas and Remarks”
