Fixture profile for Betopper Mini Spider Topic is solved
Freelama
Post by Freelama »
For your use and/or consideration.
I just put together a fixture profile for a Betopper Mini Spider LM30.
This fixture requires a dmx control software and you need to have the chases and movements put into easy macro and gobo buttons or it will take forever to program. I wish Betopper have given the user more choices for simpler DMX control options... but, here we are. I made my own GIFs for this. I put a selection of basic movements in 9 macros and I put the various built in chase sequences from channel 5 of the 7 channel operation into a gobo tab. There is a strobe feature for this fixture, however, I did not include it the profile. With the way this fixture is set up, I needed to use the strobe control to control the speed of the chases from channel 5.
Anyway this was my first from ground up profile creation. Like I said previously, I even made all new GIFs for the chase and movement patterns. I pretty happy with the way it turned out. If anyone looks at this and has any suggestions to improve or update, I'd be happy to hear from you. :fs:
DJ_NRG
FreeStyler Version: 4.1.1
Re: Fixture profile for Betopper Mini Spider
Post by DJ_NRG »
Hi I have a pair of these and have downloaded your fixture files. But I can't see this in the list of fixtures, what am I doing wrong?
He has NOT packaged the file as a PFF that does everything for you, you need to add his .fxt file to your fixtures directory and drag and drop the folder in the zip to the fixtures folder
Galifde
FreeStyler Version: 4.1.6
Post by Galifde »
Bonjour, ;)
I just purchased the LM30A, would it be possible to send me your .fxt file? I don't understand the logic of creation with the 2 Y axes
Denis
Use the custom slides to create two slides for the Y CHANNELS
