It would be very nice if there would be a "save as macro" feature in freestyler when you right-click on the faderpane.
This could be an easy way to add macro's to your fixture file. So, when you (accidentally) made a scene in freestyler that you like, just right click on the faderpane, quick-add an icon et voila, you saved it as a macro.
Save as macro feature
- FreeStyler Version: 2.69j
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Save as macro feature
Wait till the next beta, The function is known as palletes.
It can save just one fixtures "Look" or save the entire scene, so that it can be recalled and inserted into sequences easily.
The if you update the preset all your sequences will update also.
Matt
Matt
