It would be nice if you could activate the sequence by just pressing the name
Play Button Sequence
bryan19981
The play button away from the sequence name is really uncomfortable.
- Laudrin
- FreeStyler Version: 3.6.49
Re: Play Button Sequence
+1 from me, too, at least for touchscreen.
If you use the mouse on a regular monitor, it would be great to have different layouts (not only compact view) as in Submasters or Override Buttons.
For example a bigger Cue Window with big buttons / font (similar to a 2x zoom function), which would be quite handy if you work on a small screen with high resolution (I don't want to lower the resolution, it would affect the other elements, too) and use the Cues and Cuelists as a primary way of busking / managing your light show.
