Mini LED Moving Head 7x10w 14 CH Topic is solved
timberhouse
Post by timberhouse »
Hello, been looking around and trying to find a fixture file for Mini LED Moving Head 7x10w 14 CH.
I found a few but they are not the same. Does anyone have a file for this?
My email is neverknow69@gmail.com
FreeStyler Version: 4.1.7
Re: Mini LED Moving Head 7x10w 14 CH
Post by Rod_Horning »
Attached is my attempt.
I could not find an online user manual. This led me to assume that channels 1 to 4 are for PAN and TILT. If this is incorrect then my fixture will not work correctly.
After you select the fixture in Freestyler click on Window -> All (top menu item). This will open 4 additional windows (Colors, Lamp, Pan/Tilt and custom sliders). You may need to move them around in order to see all of them.
Feed back appreciated.
Mini LED moving head 7x10w.pff
(5.87 KiB) Downloaded 137 times
natalivideo
FreeStyler Version: 3643
Post by natalivideo »
better this one
7LED10W_1.pff
(38.1 KiB) Downloaded 189 times
