Lyre 30w introuvable Topic is solved
vinc1996
Post by vinc1996 »
bonjour à tous.
J'ai acheté des lyre chinoise sur aliexpress. Et je n’arrive pas a crée ou a retrouvé mes lire dans les bibliothèque.
Et après plusieurs tentative, je n'arrive pas a les crées sur fixture creator.
Merci beaucoup au personnes qui prendrons le temps de me répondre :D
http://hpics.li/f2af9db (lien du tableau DMX)
http://hpics.li/85a0c15 (photo de la lyre)
https://fr.aliexpress.com/item/2pcs-lot ... 5af60b2038
FreeStyler Version: 4.1.7
Re: Lyre 30w introuvable
Post by Rod_Horning »
Attached is a rudimentary fixture. If you post the DMX values for the color wheel, gobo wheel and macro channel (or upload a PDF of the user manual) I may be able to update the fixture to make it easier to use.
Lyre_30W moving head.pff
(3.41 KiB) Downloaded 43 times
jojobatin
Post by jojobatin »
Hello everyone,
thanks a lot Rod, this gave me a good kickstart to move forward, based on my version which looks the same ( https://www.aliexpress.com/item/moving- ... 60263.html ).
Of course, there is no pdf/more complete version of the manual...
I'm making a personal point to contribute to this forum :) I've tried to issue a more complete .pff with what I got (based on following values)
Color Wheel: ch 5
min value max value gobo color wheel
0 10 white
11 20 white/red
21 32 red
33 43 red/orange
44 54 orange
55 65 orange/yellow
66 76 yellow
77 87 yellow/green
88 98 green
99 109 green/blue
110 120 blue
121 131 blue/pink
132 142 pink
143 153 pink/turquoise
154 159 turquoise
160 255 rotation speed gradient (maybe discrete) from 40s/cycle down to ~5s/cycle (I put 223 and 255 ad medium/fast)
Gobo Wheel : ch6
I've put the values as follow
0,10,20,30...70 = white + 7 gobos (based on the predefined pictures I've found as the most similar to mine at least )
80 82 89 Gobo 7 shake (slow/medium/fast)
90 92 99 Gobo 6 shake (slow/medium/fast)
100 102 109 Gobo 5 shake (slow/medium/fast)
110 112 119 Gobo 4 shake (slow/medium/fast)
120 122 129 Gobo 3 shake (slow/medium/fast)
130 132 139 Gobo 2 shake (slow/medium/fast)
140 142 149 Gobo 1 shake (slow/medium/fast)
150/200/255 = rotation speed (slow/medium/fast)
for the macro, from 50 till 255, it's a kind of demo mode, showing the gobo and some colors/half colors.
As it's my first fixture, I would appreciate any comment :)
:fs:
p.s. some keywords to maybefind this more easily :
hong yi stage lightning
gao fei factory
aliexpress
30W moving head No Name.pff
(165.38 KiB) Downloaded 45 times
Your fixture looks very good.
I like the way you did the GOBO shake - I had never thought about doing it that way.
For rotation I've done the same as you and I have also used custom sliders. Whatever is easier for you is the way to set it up.
Thank you for posting your fixture and supporting this forum.
