Hello,
I am a owner of the Adj Inno Pocket Roll fixture and try to control lighting by DMX. I have insert DMX channels and values to the Fixture Creator. Everything works, I can change gobos, control strobe effect, tilt movement and other features. A problem happens with tilt channel. I have insert these values:
0 - 9 STOP
10 - 120 CLOCKWISE ROLL FAST - SLOW
121 - 134 STOP
135 - 245 COUNTER CLOCKWIS SLOW - FAST
246 - 255 STOP
..to can control tilt movement. If I set CLOCKWISE ROLL value to FAST, the Barrel Roller is not moving too fast (in compare to with predefined shows). I have tried change the value to any different numbers to be sure, that I accidentally didn't change slow with fast or vice verse. But not, still the Barrel Roller can't be so fast as in the predefined shows.
Please see in the image what values I have inserted for the fixture: http://imgur.com/a/4C9UY
Also in these videos you can see the difference in speed movement:
This is controlled by sound (the barrel roller is faster): https://streamable.com/iku96
..and here by DMX (I have set the maximum value for tilt movement - 120, also tried other values in range of 0 - 255, but couldn't make the barrel roller moving faster): https://streamable.com/657y0
Do you have an idea, what the problem can be? Or if you own the same fixture, please give me know your experiences.
Andrew
Adj Inno Pocket Roll - Tilt Movement is Slow Topic is solved
