Equinox Dragonfly Quad Topic is solved
dancoleman89
Post by dancoleman89 »
Hi, anyone have any ideas how I can create this on the fixture creator? I'm a newbie and don't know where to start.
EQLED101_ManualV1.4.pdf
Manual
(1.77 MiB) Downloaded 23 times
FreeStyler Version: 4.1.7
Re: Equinox Dragonfly Quad
Post by Rod_Horning »
Don't know if you still need this or not.
Attached is my attempt at a fixture.
If you would, please test it and provide feedback.
After you select this fixture click on Window --> All (top menu item).
This will open the additional following windows:
Colors
Lamp
Custom Sliders
Please notice the lower left hand corner of the Colors window. The 4 columns of black and white boxes are the RBG segments. This allows you to color the color of the 2 rows via the pallet. Any box with a check mark will be controlled by the pallet.
Equinox Dragonfly Qual.pff
(21.45 KiB) Downloaded 15 times
