I have my enttec box hooked up and four colorsplash jr in the fixxture list. I try to create a sequence, click on a fixture, pull up the RGB pallet and when I click on a color... I get [Runtime error "9" Subscript out of range] and when I click ok, then the program closes/crashes....just goes away. This only happens when I am trying to create a sequence, not when on the fly. What's the deal? If there are any other problems that I need to be aware of, please help a brother out and let me know the problems and pitfalls.
I chose this program cuz it resembles Martins Lightjockey and would hate to use another open source program, but if there is something better let me know what to try out. I'm goin for a sumwhat idiot proof operation. I know what Im doin when it comes to programing with consoles, but once programmed I need something that the DJ or whoever will be easy for them to use and not have to call me every other minute. If I had a nickle for everytime.......
Let me know what's with the error I get, and if there is a better direction to go for my situation.
I appreciate any help anyone can provide and would return in kind.
Thanks in advance,
Dan aka WIKKID
SubScript error Topic is solved
- djSupport
Re: SubScript error
send this as a bug report and see what reply you get cause it sounds like a new bug :
[bugreporting][/bugreporting]
wait for raph to get in touch
djwikkid
Re: SubScript error
I uninstalled and reinstalled(the same version) of the program and it seems to work fine now. I'll be hunting for any other bugs....and wabbits too!
WIKKID
WIKKID
- djSupport
Re: SubScript error
lol good luck!
