Im programming a show. I have programmed now 8 Scenes with almost 32 steps each.
Now im wondering how I can get them run.
Doing it with the cue is a bit complicated for me. That meens I do not have succes to start the Scene on, almost Synchron manually with a song played in Winamp. And how can I have it run Scene 1 then 2 then 3 then 4 then STOP?
Das anyone have a clue?
I looked in handling with the program DMX Creator. The do have an Sceneplayer, wich allows you to start a Scene at a spazial point of the Timecode of a wavefile. But thats very uneasy to handle!
My Idea is a Solosceneplayer or similar.
Like a Mediaplayer, where you can program, that after song 1 automaticly song 2 must start an do on.
After that the whole thing stops.
Then an "START" "STOP" and "FIRST SONG"-Buttons and Alex would be happy.
If the start of that row could be synchronised to the start of a song played in Winamp, it would solve about 90% of my Problems.
Is there an Standalong-Sceneplayer which i can connect to winamp?
