When using the built-in faders, belonging to the DMX400 controls, like speed or intensity 85% of the total range is unusable, they do not change anything.
However, the upper 10% is very sensitive. It almost looks like the controls are logaritmic instead of linear. As we are using a MIDI-controller with a small fader, setting up speed is very sensitive. Can it be changed so the full fader is linear? So 50% of slider up = 50% of max dmx400 speed
ps. Mantis is broken as we get application error #11.
DMX400 faders are not 'linear'
martie
- LJ
- FreeStyler Version: 3.5
- Twitter: none
studijo
Re: RE: DMX400 faders are not 'linear'
Hi Martie. Does the DMX 400 works normally when operating with the sliders in FS, not with your external controller?martie wrote:When using the built-in faders, belonging to the DMX400 controls, like speed or intensity 85% of the total range is unusable, they do not change anything.
Verstuurd vanaf mijn SM-G920F met Tapatalk
martie
- LJ
- Twitter: none
Even with a reset of FS or no external controls attachedstudijo wrote: 24 Jun 2017, 09:43Hi Martie. Does the DMX 400 works normally when operating with the sliders in FS, not with your external controller?martie wrote:When using the built-in faders, belonging to the DMX400 controls, like speed or intensity 85% of the total range is unusable, they do not change anything.
studijo
Re: RE: Re: RE: DMX400 faders are not 'linear'
I would suggest to re-install FSmartie wrote:Even with a reset of FS or no external controls attachedstudijo wrote: 24 Jun 2017, 09:43Hi Martie. Does the DMX 400 works normally when operating with the sliders in FS, not with your external controller?martie wrote:When using the built-in faders, belonging to the DMX400 controls, like speed or intensity 85% of the total range is unusable, they do not change anything.
martie
- LJ
- Twitter: none
Re: DMX400 faders are not 'linear'
Already did. Used notebook and two different desktops
