I have a setup where I have a Kindle fire mounted to the wall next to the door, always connected to Freestyler, and use it as the light switch for the room.
I would also like to be able to connect to it from my phone, so I don't need to walk to the door to control the lighting, however when I attempt to connect with my phone, it is stuck at connecting, and will not connect until I disconnect the tablet mounted by the door, and vice versa.
Is there a way to connect to and control Freestyler with multiple mobile devices simultaneously?
Thanks!
Connect with multiple devices?
- FreeStyler Version: 2
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Connect with multiple devices?
Freestyler only supports a single connection from any remote device.
So there is no way to support multiple connections.
