FOS Beam
Motsik
FOS Beam
Post by Motsik »
Hello!
Can anyone help me i need a fixture for FOS Beam 7R Hybrid!
Thanks !
products_0_1_0_296.pdf
(729.55 KiB) Downloaded 53 times
Motsik
Re: FOS Beam
Post by Motsik »
Dump !
FreeStyler Version: 4.1.7
Re: FOS Beam
Post by Rod_Horning »
Attached is my attempt.
After you Import the fixture and add it to the Freestyler workspace, select it and then click on the top menu item Window -> All. This will open the following helpful programming windows (you will most likely need to move them around in order to see all of each window):
Beam
Gobos
Colors
Macros
Lamp
Pan / Tilt
custom sliders
Please provide feedback.
Re: FOS Beam
Fos_Beam_7R_Hybrid.pff
(254.38 KiB) Downloaded 80 times
siomos dimitrios
Re: FOS 150w Beam ied
Post by siomos dimitrios »
can anyone help me with this fixture fos 150w beam led?
Re: FOS Beam
What help do you require?
