Adj/Elation event bar fixture file Topic is solved
oboerne
- FreeStyler Version: 4.1.7
Re: Adj/Elation event bar fixture file
Hopefully I found the correct user manual.
This is a multi-instrument fixture, ie. 4 individual lights and a controller.
There are two attached files, One file is for the individual lights and the other is for the controller. The advantage of defining the instrument this way is that Freestyler will recognize the pan, tilt and dimmer for each light as well as the master dimmer.
When you add the fixtures to Freestyler add 4 of the individual lights and 1 controller. If you tell Freestyler to add 4 lights then Freestyler will automatically set the correct starting address for lights 2, 3 and 4. When you add the controller make sure you set the starting address correctly (add 20 to the starting address of the first light fixture).
The GIF for the controller has a C in the lower left hand corner. The Movements are defined as Gobos so be sure to open all windows (click on Windows All in the Freestyler menu bar)
Please test this and provide feedback.
ADJ_Elation_Event_Bar_(C).pff- (40.8 KiB) Downloaded 27 times
ADJ_Elation_Event_Bar_(L).pff- (2.18 KiB) Downloaded 28 times
oboerne
thanks i will look on it in a few days and give you a feedback
