DTS Jack moving head fixture Topic is solved
robbiemelaet
Post by robbiemelaet »
Can anyone provide me a DTS Jack moving head fixture.
http://www.fullavl.nl/nl/index.php?cont ... achment=56
25 CHANNELS MODE (DEFAULT)
1 PAN msb
2 PAN lsb
3 TILT msb
4 TILT lsb
5 SPEED MOVEMENT
6 PAN FAR (Active only on Jack FPR Cod. 03.MS012.EBLFP)
7 DIMMER
8 SHUTTER
9 COLOUR
10 COLOUR MODE
11 GOBO
12 GOBO MODE
13 GOBO ROTATION / INDEX – PRISM ROTATION
14 GOBO INDEX FINE
15 GOBO SHAKE
16 FIXED GOBO
17 FIXED GOBO SHAKE
18 IRIS
19 MACROS
20 MACROS MODE
21 PRISM
22 FOCUS
23 FOCUS FINE
24 ZOOM
25 RESET + LAMP
FreeStyler Version: 4.1.7
Re: DTS Jack moving head fixture
Post by Rod_Horning »
If anyone is working on this please comment. I've started to develop the fixture but will stop if anyone else is doing so. It will take me a few days as I am involved with 2 major productions and do not currently have a lot of free time.
Post by Jan_K »
I had some functionality in Fixture creator to test so I made this fixture.
It is not tested but give it a try.
DTS_Jack_Spot_25ch.pff
(316.44 KiB) Downloaded 28 times
robbiemelaet
Jan_K wrote: 08 Mar 2017, 07:48 I had some functionality in Fixture creator to test so I made this fixture.
I tested it with the 3D-viewer in Freestyler.
Everything works I think, but I don't see any color changement when I change the color....
Can you see color changement on a moving head in the 3D viewer?
Post by Jan_K »
I can see that the output on channel 9 changes in the output monitor of FreeStyler. This means that Freestyler changes the color channel so I think it is an error in the 3D viewer model.
"Output -> Show Output"
