Sorry but I could not find anything about this in the forum...
We are trying to adjust the Cue speed by dragging the slider with a mouse. It will only increment from 88 to 92 to 96 to 99 and so on. Is there anyway to move the speed in increments of 1 by using the mouse or a PC keyboard command? We are not using a touch screen or external interface to control Cue speed. I installed the latest version 3.6.37. We were previously using 3.5.5 and we have a USB-DMX512 interface.
Thank you, Fran
Adjusting Cue Speed
- Narfman96
- FreeStyler Version: 3.5.7
- I Use FreeStyler for: Band
- FreeStyler Version: 4.01
Re: Adjusting Cue Speed
Should be able to highlight fader then the "+" and "-" keys will do what you are asking
- Narfman96
I can drag the slider but I cannot figure out how to select it so the "+" and "-" keys will change it???
My bad, the +- only works on channel faders
