Super beam 4x25w movin head from AliExpress Topic is solved
skar18
Post by skar18 »
Please somebody help me, i need a pff file from this fixtures
https://m.es.aliexpress.com/s/item/32688747668.html
:D
Here is the manual
http://www.fenglighting.com/Upload/File ... 58298c.pdf
FreeStyler Version: 4.1.7
Re: Super beam 4x25w movin head from AliExpress
Post by Rod_Horning »
Attached is a fixture file that I think will work. The manual did not have a lot of information so the fixture file does not have any macros or custom sliders but all 15 channels are configured. After you add and then select the fixture you will want to click on Window and then click on All.
I have no way to test.
Any feedback will be appreciated.
skar18
Post by skar18 »
Thank you so much, i'm gonne to test it
skar18
Post by skar18 »
It is working perfectly thank you so much
Thank you for the feedback
