ADJ Mega Tripar Profile Plus 9chor 10ch Topic is solved
foshak
Post by foshak »
Hi!
In the "Complete Fixture files" package (viewtopic.php?t=4528), there is a fixture file for the ADJ Mega Tripar Profile Plus for 9ch. I get an error when I try to import this fixture into Freestyler. It states that the file is 0 bytes, even when it is not. I have also found the zip file from 2015 containing the same file it it, but that returns the same issue. I am able to import other fixtures from the same file.
The 6 channel profile for it works great.
Is anyone able to open the fixture file for this profile, or does anyone have a working one for 9ch or 10ch? Preferably 10ch.
Thanks!
Regards, H
Re: ADJ Mega Tripar Profile Plus 9chor 10ch
Post by Jan_K »
It is a fixture I have created and when I try to import it again then I get the same error.
Unfortunately when I tried to import it Fixture creator deleted the original fxt file so I don't have it any more.
I have reported the import error and are waiting to see if it can be retrived.
