newbie eyourlife fixture creator attempt Topic is solved
djmuttzy
Post by djmuttzy »
hiya all semi newbie to here I have been and brought two new types of light for my dj setup and I have generated ( I think ) the fixture but I'm not sure on how to add some of the other channels as there is no part that explains it ??? ( at least I think not ) can someone check it and let me know if I have added everything correctly or not
eyourlife RS-063.gif (2.59 KiB) Viewed 177 times
T I A :fs:
eyourlife RS-063 dmx channels list.pdf
(221.67 KiB) Downloaded 39 times
RS063.pff
(39.8 KiB) Downloaded 33 times
Re: newbie eyourlife fixture creator attempt
Post by Jan_K »
Hej.
I have had a quick look at your fixture and it looks okay.
However there are some minor things which can be improved.
1:
Channel 6 is also dimmer channel. Meaning that you can control intensity on it. 0 - 100%
I would set the field "Intensity channel" to 6, min = 134, max = 8
And then "Shutter ch" open = 8.
You need to verify this as I recall that FreeStyler have had some problems doing this correct.
2.
The gobo 1 I think that should be a white dish to symbolize an open clear beam with no gobo.
Also you can add the shaken gobos by repeating the images and then add the values for shaking.
Or you can add them as macros
djmuttzy
Post by djmuttzy »
hiya Jan_k
thanks for the info I will amend the advisorys and retry the fixture .... thanks for the help really apopreciated !!!! :0)
