Behringer X-TOUCH Control Surface
Gary@hosanna.net.nz
Post by Gary@hosanna.net.nz »
Is it possible to get a Midi Map for the Behringer X-TOUCH Control Surface for Freestyler. The touch sensitive & quieter sliders are a big plus on this machine over the BCF2000. The Compact X Touch does not have page changing ability and I think it may be possible to have page change on the larger controller of the Behringer X-TOUCH Control Surface.
Does anyone know about page change ability and the Midi Map.
Gary
technote
Re: Behringer X-TOUCH Control Surface
Post by technote »
I have found that the controller as is is not great for the software, that being said, if you use a midi translator (I use BOME) it becomes a pretty decent little controller!
Gary@hosanna.net.nz
Thanks for that. I only just discovered your reply.
Schuim
FreeStyler Version: lates
Post by Schuim »
-BUMP-
So? Anyone got it working like the BFC-2000 yet or is it "impossible"
