Lixada 5LED 50W Beam Wash Double Sides RGBW 15 / 21 Channel DMX 512 Infinite Rotating Moving Head LED Stage Pattern Lamp Topic is solved
Re: Lixada 5LED 50W Beam Wash Double Sides RGBW 15 / 21 Channel DMX 512 Infinite Rotating Moving Head LED Stage Pattern
Post by Jan_K »
Hej
I may have overlooked it but I did not find any DMX chart.
Post by Jan_K »
No.
Only payment and shipment as fare as I can see
Sorry I was also a bit to fast. :D
Post by Jan_K »
Hej again
Here is a basic fixture.
All channel mapped.
There are no values in the DMX chart so you have to find them yourself and enter them in the fixture.
So there are a lot of work for you to do.
Lixada_5led_beam_wash_RGBW.pff
Have fun.
Post by Jan_K »
first no. ;)
I still think you have a lot of fitting to do.
You need to run through all faders and see what they do and fit then.
Example. Strobe does it start when you press min or is the min value wrong.
Also there are "Y axis infinite rotation" what is the function and shall it have a macro.
channel 17 - 20 what are the function and as above, shall they have macros.
So as mentioned above you are not finished yet. :D
perrip
Commited FS Forum helper
FreeStyler Version: 4.6
Post by perrip »
Hello Jan, do you know if the person you were helping with this ever got it finished? just wondering, I have the same light.
pardip
Post by pardip »
i also have the same light does anyone have a finished file...
perrip
Post by perrip »
I just checked it out, it works great, Jan did an amazing job, all the important options are there.
