Hello guys
Does anyone have any fixture made to the equipment "Stairville HL-x18 QCL Rgbw Flood 18x8W"? The link to the manual is as follows, and intended to version 8 dmx channels ....
https://images6.static-thomann.de/pics/ ... online.pdf
The equipment is similar to Eurolite CLS 18x8w RGBW
Thank you
[Request] Stairville HL-x18 QCL Rgbw Flood 18x8W Topic is solved
- FreeStyler Version: Beta
Re: [Request] Stairville HL-x18 QCL Rgbw Flood 18x8W
Hej Tristan
Just a small comment.
Please use the brand name. (Stairville not Thomann)
Others don't know where to find the fixture as they will search in the Stairville folder
And if you don't have an image of the fixture then I think there is a image "noPic.bmp" which can be used.
Looking forward to see an update on this fixture.
