Chauvet Slim Par 56 3 ch mode, file needs a tweek
perrip
Commited FS Forum helper
FreeStyler Version: 4.1.7
Post by perrip »
Hello, sorry I am new to freestlyler and am a spaz I have a fixture file for a Chauvet Slim Par 56, that does not seem right, it opens with a moving head option and no lamp on- off function. I opened it up in fixture creater and just made a mess of it, I was hoping someone could help me it is a really simple led par and in 3 channel mode it is just
ch 1 red 0-255 0-100%
ch 2 green 0-255 0-100%
ch 3 blue 0-255 0-100%
I have attached the fixture file,
Thanks for any help you can give me.
Paul
Chauvet_SlimPAR_56_(3 Channel).pff
(3.9 KiB) Downloaded 21 times
Re: Chauvet Slim Par 56 3 ch mode, file needs a tweek
Post by Jan_K »
Hej Paul
I am not sure what is wrong.
When I look into you fixture file then it is okay. Nothing wrong.
However I noticed that you used a special char "TM" so I tried to rename your fixture and that removed the movement panel.
SlimPAR56_3_Channel.pff
(3.91 KiB) Downloaded 24 times
perrip
Post by perrip »
Oh great, thank you so much, one more quick question, this fixture does not seem to work in the fx mode, is that because there is not a lamp open closed button in the file? thanks again for your help!
Post by Jan_K »
You should be able to use FX on the red, green and blue channels.
As the intensity and shutter channel isn't defined then you can't use FX on these functions.
perrip
Post by perrip »
Great, thanks so much! I'll have to work on defining them. I appreciate your help
-Paul
