Suggestions Topic is solved
technote
Suggestions
Post by technote »
For me as a non professional... How would you suggest setting up non movers to keep the lighting design interesting? I only have the budget for led washes and conventionals for an upcoming gig but I want the design to look good, be interesting, and not get repetitive...
the lights I will be using
16 Par 64's (Running off of DMX Dimmers)
10 MBT Led Par96
4 Chauvet SlimPar64
2 Chauvet ColorStrip Mini
4 Chauvet ColorStrip
2 Chauvet IntimidatorSpot LED 150's
Thanks in advance for any suggestions!
spud1511
FreeStyler Version: 3.5.7
Re: Suggestions
Post by spud1511 »
Suggested reading: submasters wiki.
Using submasters allows you to split attributes and program stuff separately. So you can have a bunch of movement sequences for your intimidator spots, etc. which can be used in different combinations of colours or chases so even when you run the same sequence the second time it won't look exactly the same.
Other than that keep building it up through the night, as in don't use all your best effects until later on. That could mean starting with really simple all 1 colour, no movement, and keep introducing new elements (different colours or colour combinations). You can then bring in colour chases and movement (again suggest slow or limited at first and build it up).
That's my little input, but there are loads of guys doing a great job who all approach gigs a different way so there is no real correct answer how to do it. Ultimately it comes down to a bit of practice and personal tastes.
