LedTrix Letter size Problem
bluedragon88
Post by bluedragon88 »
i used it with my revo 4 wit 8x8 Matrix but i miss the last line on Top the Letter are to big with the Letter MS Sans Serif can anyone help me?
Re: LedTrix Letter size Problem
Post by Jan_K »
If I recall correct then it is a bug and it is reported in the bug tracker.
LedTrix can't go below 9 in text size.
bluedragon88
ok when will be fixed ? ;)
Post by Jan_K »
No idea.
It has been reported a long time I think and it probably don't high priority on the developer side.
bluedragon88
ok
Return to “Suntrix & LedTrix plugin”
