video card not compatible with directx9
sowndman
well, I upgraded to the latest freestyler along with easy view.Just after I click the ok afyer selecting the universes I get the direct x error. I'm running win7 on a netbok with 2 gigsof ram. i currently don't need the extra universe so I would like to go back to thepreius version. I can loud the single universe version but it still wants to load the newer easy view. how do I get it to load the older version of easy view? I tried just renaming the easy view but then I get dll error. I can load the old version manually. the new version loaded manually gives me te same direct x9. error.
Nathanrs93
- FreeStyler Version: None
Re: video card not compatible with directx9
Have you tried using google to see if it's a common problem?
krissherbert
I had this problem on just about every PC I tried it on
