Chauvet Intimidator Spot LED 255irc
soundsinvision
Post by soundsinvision »
Has anyone got a profile for this? I haven't updated to the latest version to see if it's included yet (wasn't aware it was out - I will try it tonight).
TIA
DJBlacklabel
Re: Chauvet Intimidator Spot LED 255irc
Post by DJBlacklabel »
i used the spot led 250 profile since it has the same DMX channels as the 255irc
musicmaestro
Post by musicmaestro »
Has anyone got this profile? The 255 IRC has 13 channels while the old 250 profile shows up as 8 channels and doesn't work right at all. Help for a newbie would be appreciated! :-)
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Please test this and provide feedback.
Be sure to click Windows All after you select the fixture in Freestyler
Thank you
Chauvet Intimidator Spot 255.pff
(124.75 KiB) Downloaded 212 times
Return to “Chauvet”
