MBT Par96
Jorgens
MBT Par96
Post by Jorgens »
Anyone else using these old duffers? the drummer found them in his garage... I have the manual but cannot get ANY control on them.. dip switches are set right to the dmx channel. but all they do is flash random color patterns no matter what i tell it to do in freestyler.. I know these are old and like one of the first led fixtures out there... I'm hoping im just missing some little trick on these old dogs... thanks!
Nathanrs93
FreeStyler Version: None
Re: MBT Par96
Post by Nathanrs93 »
http://mbtlighting.com/Uploads/PDFManuals/LEDPAR96.pdf
It says that you need DIP switch 10 on for DMX Mode, then set your address with DIP switches 1-9
prefectart
Re: MBT Par96
Post by prefectart »
i just spent a hour building a fixture for a mbt par dl 64 rbg. the manual i spent hours looking for also didnt have crap for dmx info in it. odd. good luck!
JTThunder
Re: MBT Par96
Post by JTThunder »
I still havnt figured out how to use the MBT Led Par96 in freestyler....Anyone got them working?
