Check out the new site logo at the top!
let us know what you think!
New Site Logo
matt
- Admin
- FreeStyler Version: NULL
Tom
Re: New Site Logo
Just a thought - could it not cause a fit for epileptics? Should a warming not be placed somewhere or the option of disabling it?
- djSupport
Re: New Site Logo
I've had one before and so I concour
matt
- Admin
SilentShaddow
Re: New Site Logo
I got bored and decided that I wanted to try and contribute... It would need the text adding,
I was going to blur out the text, but I decided that there really wasnt any point in hiding the text as its obvious enough anyways. When I googled it was the head that I liked the most. If anybody has a problem, then let me know.
You will need to view the image location to see the entire image, but you get the idea, ive also noticed some untidyness around the light 'arcs?' which I need to tidy up, other then that what do you think?
The light beam can come in any colour as this very 'special' edition of the 575 comes with CMY mixing
Edit: Added a smaller image>?
Example of Colour:
Feedback/thoughts etc? Or not really?
Example of Colour:
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: New Site Logo
I really like the top one,
Must admit iv stolen it for my desktop, if you could export a version to fit 1680 x 1050 would be gr8 lol.
Matt
Matt
SilentShaddow
Re: New Site Logo
If you like it that much then I shall tidy it up for you a bit, I like it myself (desktop also
) but its not what It could be, I shall do some work on it. Anyway, If you want to use it, then you are free to do so I dont mind if its freestyler/desktop/what ever really...
SilentShaddow
Re: New Site Logo
There, I added some text, and cleaned the lines up a bit, its should hopefully be the right size now as well so, if anybody wants to use the image feel free to. You can continue to use the image hosted at that location at well if you wish.
