lighting effect with LED
- FreeStyler Version: 3.45
good morning. I am looking for how to remove or mitigate the ignition effect on 64 led.Je to explain when the PAR64 is extinguishes and I turn it on it goes from 0 at power too quickly there not to like ny projo of a progresive trad climb when the power is tension.Voila thank you answer me to give us your tricks to get around is problem with LED
Re: effet allumage avec led
- FreeStyler Version: 3.5.7
Re: lighting effect with LED
0 to 100% (or 100 to 0) in a 100ms fade?
Hello, I do not understand 100ms fade ????
I think of 0to 100
I think of 0to 100
100ms = 1/10th of a second fade from zero to full power, instead of an instant snap.
Or longer, 200ms would produce a slightly more gradual version of the same thing.
ok but in 200ms or display crteate sequence or the fixture
Hello!
perhaps a bit too late but yes if you want a progressive On or progressive OFF effect you have to use the fade function.
- First case : light from 0 to 100% :
create a scene where you set the chanel parameter on FADE (not OFF, not SNAP) and then apply a value of 255 (100%)
- Second case : light from 100% to 0 :
create another scene where you set the chanel parameter on FADE (not OFF, not SNAP) and then apply a value of 0.
Now create a sequence with these two scenes. You can select independently and for each scene the fade time and scene time (if you want a complete fade on the whole scene time, you may choose a fade time = scene time)
Now play the sequence, your light should fade ON and fade OFF.
Note : Freestyler doesn't display the fade value in real time, you will only see the value you set for each scene (so you will see 255 for the first scene, and 0 for the second one).
Hope I helped you!
Crok'
Hope I helped you!
Crok'
- FreeStyler Version: 1
The 16th China International Lighting Fair (Autumn Fair) will be held from 22-26 October, 2015 at the Guzhen Convention and Exhibition Centre in Zhongshan City, Guangdong Province.
100 or 200ms is the fade time. It is in the sequence editor.
