Wish: include file in create sequence
Chester Wilson
Post by Chester Wilson »
It would save hours of programming if it were possible when creating a sequence to insert a previously-created sequence, with all its steps, before or after the current step. Then one could go back and delete any unwanted steps, change the fade and display times, or add in other steps. Currently every light has to be set up every time it is used, and this is very time consuming.
Anyone else like this idea?
Scrinson
Re: Wish: include file in create sequence
Post by Scrinson »
Yes please.
Return to “Ideas and Remarks”
