Help with Fixture Files - LED Beams
Uriahdemon
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Post by Uriahdemon »
I was wondering if anyone can please help me with some information on a fixture build I am putting together for an ADJ VBar. I have built something that I can get to go on and off which is fine but I was wondering how to get some beams on Easy View 3D. I have tried everything I know and any ideas anyone can help me with would be much appreciated. I am particularly interested in Mode 7.
I have attached the fixture file I have been working on to date and also the manual.
Thanks for your help in advance.
ADJ V Bar.pdf
(925.25 KiB) Downloaded 122 times
ADJ - VBAR PAK.ssl2
(15.88 KiB) Downloaded 133 times
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Help with Fixture Files - LED Beams
Post by buttza »
Are you talking about the actual beams showing from the lights when they are on? If so go to the toolbar at the top and click on Rendering. No adjust the Ambient light slider and Light beam slider.
If you are talking lasers, Good luck. :)
If you are talking Barrel beams you can adjust that in the fixture file editor.
Uriahdemon
Hi, thanks for your post. I am talking about the (barrel beams) produced by the fixture. I am aware of the rendering and my other lamps are set just nice on EV3D but I just cant get any beams on this one. As you say it should be in the fixture file editor but I cant get anything to show at all. Did you have a look at the file I attached...??
