Hi Me again,
another fixture i have is a Cyclope from jb systems.
I did my best to make the 10 channel version but the pattern ,dmx list got me confused.
Can someone help me with this.
Thanks in advance
JB SYSTEMS Cyclope
rrara
JB SYSTEMS Cyclope
cyclope.pdf- (2.82 MiB) Downloaded 52 times
CYCLOPE.pff- (3.67 KiB) Downloaded 46 times
- FreeStyler Version: Beta
Re: JB SYSTEMS Cyclope
Hej rrara
This one is a bit difficult to create a decent fixture for.
You have 7 clusters and each has 25 patterns or colors.
It giver a lot of combinations.
One thing you could do are only making a 4 channel fixture as a start and then manually figure out what value each of the patterns or color has.
These values you then can enter as a macro.
There is only one way and that is changing the channel 2 value and then record the value where the pattern or color shifts.
