54x3w LED Par 64 Fixture
Corman76
FreeStyler Version: x2
I Use FreeStyler for: Church
Post by Corman76 »
This is my first post on this forum so please forgive me if it is not completely to standard...
I recently got some 54x3w LED Par 64 DMX lights (probably Chinese as I can't find a specific brand) and I am trying to create a fixture for it in Freestyler. I believe I have most of the channels setup correct, but the last two channels are for program functions (strobe, hop, pulse, sound activate, etc) and I'm not sure if I have setup these correctly. Do you setup channels for this and use macros for the functions or are the functions setup differently.
Can someone please review the attached DMX table for the light and the attached freestyler fixture file and see if I have set it up correctly or not....Any help is greatly appreciated..THANKS!!
LED Par64 - 54x3w.pff
Freestyler Fixture File
(12.02 KiB) Downloaded 107 times
54x3w LED Par 64 DMX Chart.pdf
DMX Chart
(69.11 KiB) Downloaded 101 times
Corman76
Re: 54x3w LED Par 64 Fixture
Post by Corman76 »
Has anyone had a chance to look at my files??? Any comments??
mannaija
FreeStyler Version: 4.1.1
Post by mannaija »
Anche io ho questi problemi, però i canali supplementari non li ho messi nelle macro, ma nell'ultima Tab, credo sia custom o una cosa del genere...buona fortuna ..io non riesco ad attivare la luce bianca...
Hi, I'm on mobile so can't check files but yes, functions etc can be setup on the macro window, just create a little .BMP file that has text on to tell you what it is and I usually have a button on the macros set at 0 saying something like 'func off' it just turns the channel too 0
If you have multiple strobe options use the main one on the dedicated strobe page then create custom sliders for the others setting the channel and the min and max values for that option
