setting up movments for chauvet minispot Topic is solved
terry143
how do i creat movments for 13 ch chauvet minispots have four and want them to do different things not just the presetup movments in freestyler x2
- buttza
- FreeStyler Version: 3.6.4
Re: setting up movments for chauvet minispot
Best way is to use the effects generator.
Eg. Select all the lights you want to move.
Now select New Sequence then FX generator.
Select Sine Wave.
Adjust the Amplitude and Offset.
Check distribute evenly
then generate.
Should see 11 steps created. This will create a tilt wave effect. click the play all steps button. Should be a double arrow right.
That is one effect and will fan the lights in sequence.
Refer to FS wiki for more info.
Select Sine Wave.
then generate.
